I just received the water pump impeller kits for my Yamaha outboards. The Seloc manual says to turn the drive shaft clockwise as you lower the new metal cartridge over the new impeller. I understand that part, but my question is: Do you still turn the drive shaft in a clockwise direction on a counter rotating engine. I don't know if its the engine itself that is counter rotating or just the lower unit gears that make the propeller counter rotate. This may be a simplistic question but the only way to learn is to ask someone who has experience.
Paul
Paul
