good evening, i'm new to your forum and i'm looking for some seasoned Yamaha outboard owners. I ran into a problem with my 1988 yamaha 40 Hp 3 cylinder oil injected outboard yesterday. The three nuts that hold down the flywheel simply vanished. The flywheel hit the starter and broke the upper hold down bolt leaving 1/2 of the bolt inside its mount. I examined the flywheel and there are no broken teeth but besides the three bolts that hold the flywheel in place, there seems to be a series of several rivets and they have all been eaten away. Are these rivets important or will the three bolts that i have replaced suffice to hold the flywheel in place? What would be recommended to tap the remaining broken bolt out so that i can replace it with a new one?
thank's for you help,
Beaupar1
Beaupar1
