Fuel flow guage off 15%, suggestions???
  • Fuel flow guage off 15%, suggestions???
    I have a 2004 boat that I bought used this spring. It has the digital fuel management system with twin 150's. Filled up and zero'd out the system when I put the boat in the water. Just filled up for the first time and the fuel flow reading told me I needed 111 gal but the actual amount for the fill up was only 94 gal. This is 15-17% off and the system can only be calibrated 3%. Any suggestions on what to look at and how to remedy this would be greatly appreciated.
    It can be set -4% if the gauge is reading too high but no more than that. Need to record fuel usage and gauge readings for three trips and then use totals to make corrections.
    Regards,
    Boats.net Forum Admin
    Buy Yamaha Outboard Parts at
    Discounts Up to 80% off Retail!
