Hi,
I have a 2000 (manufactured in 1999) 90 hp Yami model # 90TLRY. Last season I noticed the telltale stream started to get a little weak. This spring I ordered a water pump kit from Boats.net and rebuilt the pump. (Note, when disassembled, while the old impeller was a little brittle, it appeared to be whole).
During the rebuild, I noticed a thin layer of corrosion on the drive shaft where it comes out of the water pump housing. After struggling to get the old impeller over this section, I removed the corrosion with a strip of fine emory paper so I could slide the new impeller over the drive shaft. I did not go crazy here, just enough pressure with the paper to remove the corrosion.
After replacing the lower unit, I put muffs on the engine, turned on the hose and started her up. Water did come out of the telltale, but it is still a little weak. Also, there was quite a bit of water flowing out of the large hole in the lower unit where the shift shaft and speedo tube pass through. Because the telltale was still a little weak, I took note of this. To tell the truth, I can't remember if water came out of there before. My first thought was that I misaligned the water tube/water pump connection. So I pulled the lower unit and checked it. The tube appeared to be in the correct position and it had a coating of grease on it - that indicated that it did seat in the water pump grommet.
I took the lower unit over to a bench (still off the engine), connected the muffs, turned on the hose and watched what happened. Water came out of the top of the water pump around the shaft as well as out of the water pump outlet. This is probably where the water I saw exiting the gear/speedo hole was coming from.
I left the lower unit off and am trying to figure out what (if anything) is wrong.
Questions:
1) Is it normal for water to flow out of the top of the water pump housing when water is introduced under moderate pressure by a hose and muffs? I don't see any seals around the drive shaft in the schematics on Boats.net. The order of parts on the shaft is the impeller, the ss housing cup and the white plastic pump housing.
2) Looking at the Lower Casing Drive 3 schematic on Boats.net, I notice that there are two parts on the water tube that were not on my engine when I disassembled it:
List # 4 (90430-12072-00) Gasket, and
List # 1 (663-44367-00-00) Water Seal.
The only seals around the water tube where it enters the pump are a grommet (list # 15) that serews into the water pump and a water seal that sits in the water pump outlet under the grommet (list # 14).
Are these parts (list 4 and 1) indeed missing? If so, would they mean a major leak that would prevent a strong water flow to the head, causing the weak telltale stream and the water flowing out of the shift/speedo hole?
Assuming that the parts in question are not on my model, and that it is normal for water to flow out of the top of the water pump housing, my plan is next to make sure that the telltale hose is not partially plugged and to back flush the engine using the hose connection on the engine to see if water frelly flows down the water tube (to ensure that nothing is plugging the water tube).
Answers to my questions and any other suggestions would be most appreciated.
Thanks for your help!
Questions:
