What's the Oil Consumption on a 50TLR-
  • What's the Oil Consumption on a 50TLR-
    I've been trying to locate the approxmate oil consumption, per operating hour, on a 2 stroke 50 HP (50TLR)
    I understand it will vary with throttle position and RPM.
    But would like to have some idea of usage.
    Thanks !!!
    It uses a 200:1 oil ratio at idle to 50:1 ratio at wide open depending on throttle position and engine rpm's.
      OK I understand now.
      So at wide open throttle it consumes 50:1 or about 13 oz of oil for 5 gal gas or 39 oz oil for 15 gal gas.
      With a 15 gal gas tank and and a 1 1/2 Qt(48 oz)(onboard) oil tank, I would run out of oil(and gas) in about 3 1/2 hours at WOT.
      I just didn't correlate the two values before.
      Thanks !!!
