CDI testing
  • CDI testing
    If I test the CDI with a regular multimeter at DC volts is it correct that I will not get any reading at all.
    Will a voltage only show on a peak voltage meter ?
    When testing CDI output voltage you will need a peak reading voltmeter, some digital voltmeters make a direct voltage adapter that you can get to read peak voltage.
