Stalling 9.9
  • Stalling 9.9
    I have a new 2007 Yamaha 9.9 high thrust 4 stroke and after about an hour of *****ling the motor quits. It's like it runs out of gas. I can get it started again by depressing the primer bulb, however, it only stays running for a minute or so.
    Any suggestions?
    leaks in fuel line the tinyest leak would cause problems....primer bulbs do go bad somtimes.......fuel pump but thats no common
      Still under warranty. Drop it off let them fix it.
        Thanks for the tip, i'll check the lines plus replace the primer bulb. So far the dealer hasn't been any help.
          I know this is the obvious but make sure your tank is vented well.
