Trim Sender Adapter?
  • Trim Sender Adapter?
    Recently replaced my 1999 40HP 2-stroke (Model# C40TLTX)motor with a 2004 50HP 2-stroke (Model# 50TLRC).
    I have a Yamaha Multi-Function Tach (part# 6Y5-8350T-82. The 2004 motor has a 2-wire trim sender, the 1999 motor has a 3-wire sender. The tach harness has a plug that fits the 3-wire sender on the 1999 motor.
    Is there an adapter made to adapt the 2-wire trim sender to the 3-wire plug that will enable me to use my current tach and harness?
    Model # on the '99 40HP should have been C40TLRX. Could not edit original post.
