Ihave a F50 TLRZ, 2001, when I hit the throttle it bogs real bad or sometimes dies. I cleaned the carbs, they looked good. Any help would be appreciated.
If you didn't change the settings and kept all the jets clean I think its possibly the float / needle seat are restricted from closing or opening. Based upon your intial description I assume that it's not getting enough fuel as you throtle up. Check to see that the plastic sleeve is not binding with the float within the bowl which may restrict the seat from opening fully allowing fuel.
I cleaned only. The needles moved with floats when I reinstalled them. It seems to run fine when I ease into it. What about the accelerater pump, could it be faulty? Are the little black hoses running to each carb from the pump supposed to have any gas in them?
Any help is appreciated.
