tach installation
  • tach installation
    i have a 1994 sws 200 series outboard and i have installed a new digital tach (original new yamaha) unfortunatly the tach just reads 00 but the trim function and oil function works properly. i would like to know how to check for the tach signal ? i know the green wire goes to the tach. can i check the green wire with engine running with a multi-meter ? and what should i look for ? i'd also like to know how to check for a signal comming from the rectifier ? any help sure would be appreciated.
    thanks stoney
    You should get about 15 volts ac between green wires at engine and about half that between green wire and ground at tach.
