I am trying to re-seal the tilt ram and for the life of me cannot figure out how to take the ram apart to slide the seal cup off. The top of the shaft has the eye that attaches to the engine bracket. This appears to be welded in place. The lower part of the shaft is either pressed in or screwed in. Not sure. Anyone ever try to reseal this?
96 vx 250 tilt seal
Yes that was the easy part. How do you remove the retainer from the shaft ? The trim rams (small ones) slide right off. The tilt ram (large one) has the eye welded on the top part. I removed the entire ram and the other end has the piston either pressed or screwed on.
ÂÂÂÂÂÂÂÂ
