I ordered and installed a 6Y5-83540-05-00
PRO SERIES TACHOMETER with oil indicator(2 Stroke Oil Injection models),tach connection was easy, not sure about oil light connection. I extended the wires for the oil lights to the engine, there is square connector below the air intake that is not connected to anything. Is this where I connect? Do I disconnect the square 2 wire connector from the oil level sensor and connect there? Not sure. Thanks.
