Hi all. I am new to this forum so hope this is done correctly. My problem is 1986 Yamaha 115 has no spark to any plug. I have twins, one cranks and runs fine the other has no fire. I swapped the CDI unit, the stator, and the trigger coil from the bad to the running motor, one at a time. That motor still runs fine. The one that didn't still doesn't. I also bypassed the kill switch. Any idea,s I am out.
No Spark 1986 115 hp
Disconnect the white wire at CDI box to eliminate stop circuit. If it has no fire at all then it is usually the CDI or Charge coil.
I am new to this but i have 91 yamaha salt water series 250 hp and i am having the same issue, i have not had a lot of time to trouble shoot it, but i have fuel but no spark on any of the six cylinders. kill switch is in place but i have not bypassed it yet. ill have to try those out tomm. thanks
ÂÂÂ
