F60 carb rebuild/clean
  • F60 carb rebuild/clean
    I'm planning to clean my carbs soon. Which parts are must replace. I was going to replace all 20 o-rings that mount the carbs and four bowl gaskets. Anything else I should replace. This motor is only a 2002. Also do the carbs need to be resynchronized? If I'm reading the Seloc service manual correctly, synchronizing isn't necessary. What do the experts have to say and any tips would be appreciated? Best carb cleaner, etc?
    Are you 100% positive about the resinc? The Seloc service manual states it's not required for a carburetor overhaul.
      Now I'm really feeling stupid. Just changed out the primer bulb. The old one has a rattle in it. Could this have caused the fuel restriction at high speed?
        Yes sir. The little things will get you every time.
