Can someone help me out with winterization on this motor. Have winterized 2 stroke carb motors in past with no problems. Anything I should be aware of with this motor?
winterization
Add fuel stabilizer to fuel and run boat long enough to get stabilizer to go through entire fuel system. Remove air silencer and Fog engine.
Remove spark plugs and spray Foggig oil into cylinders, install spark plugs, pull landyard cord to prevent engine from starting and spin engine over a couple of cycles to get oil on cyl. walls and rings. Disconnect fuel line from engine and drain the fuel vapor seperator tank. There is a brass drain screw on bottom of vapor tank. you can cut the bottom of a gal. plastic jug to put under drain screw so that you dont spill gas inside cowling.Change lower unit oil and grease all fittings
