Power trim pump seems to ahve a leak where the pump motor sits on top of resevoir. Looks like screw in forward port corners is where the leak is coming from. Is there a quick fix or do I neeed to go thru the whole routine of removing the entier trim cyliner/pump assemlbly to repair?
Trim Pump Leaking
http://www.boats.net/yamaha/partsyst...oard&year=2000
start here
i do see some seals
try in the PT&T (power trim and tilt)
I know this is an old beat up subject but...I personally have an 03 F225TXRB and have a very slow leak from my rams. My question is if I get a kit would it be the 69J-4380P-00-00 PISTON SUB ASSY or the 69J-43820-00-00 TRIM PISTON SUB ASSY ? Both are listed under the trim diagram page. Any help with this would be great...
ÂÂÂÂÂÂ
