idle issue
  • idle issue
    Hopeing someone could shed some light on what would cause my 115 2 stoke not idling? Could this be a filter problem. A mechanic and suggested the 4 carbs would need rebuilding...I have 400hrs, second opinion anyone?
    Appreciated
    Thank You
    Fish or starve
    Dirty carbs is the most common reason for idle problems. Check compression before rebuilding carbs to make sure it's not a low compression problem.
      Two carbs, pretty easy job should cost about $250.
      Once it's done MAKE SURE YOU HAVE A RACOR FUEL FILTER INSTALLED. These days plan on having done pretty often or learn how to do it yourself.
