i can no longer run a 2001 ox-66 on muffs, it overheats. tried two different kinds of muff, pressure from one side only and a dual feed.
i changed the thermostats, pulled lower unit checked water pump (only a year old) it looks fine to me. did a search here on poppit valves (water pressure relief valve). bought a new one with the mushroom head on one side. confusing installation instructions from the search.
does the re-designed valve with muchroom head go towards the motor/power head or do the fins go towards the power head?
when i pulled the old one out their was no trash in the opening. finally, i also bought a new grommet, the old one seems hard to get out? it also seems to me that with amount of spring tension, if i install the new one it would just be pushed through and end up in the passage way. maybe their is a ridge in the back of the passage way so that will not happen....don't know the old one is still in place.
