Yamaha 2000 115 HP Lower Unit
We had to put alot of downward pressure on the propshaft to remove the bearing carrier. When it came out, the ball bearing and reverse gear stayed in the LU. I cannot get the bearing gear assembly to come out. When I pull up on the propshaft it seems to hit something really solid. I believe the propshaft / bearing / reverse gear is supposed to just come out. But, it will not. Any ideas???
Thanks,
Kevin
Thanks,
Kevin
