changing trim fluid 97 200 v max
  • changing trim fluid 97 200 v max
    how do you add or change fluid do you loosen plastic cap to add?
    well to actually change the fluid completely, you have to tear the t/t unit down. but if you want to add it, then tilt all the way up, remove the fill plug and add till it is even with the bottom of the fill hole and replace the plug.
    Michael Babuchna
      thanks for the help will try today
