My VX225 has lost the spark on #6. I have changed the spark plugs, #6 is always wet but never shows any sign of a spark, spark plug wire, and ECU with no change. I have cleaned O2 sensor and checked all connections. Motor was running fine most of the day. Started to get on plane and it coughed and skipped similar to a plug fouling but would not and still won’t, get above 4600 RMP under load. There is no back fire or coughing like a misfire. All other cylinders are working fine except #6. Any suggestions?
VX225 no spark in #6
A little confused….. how would the lower lift pump that just pumps fuel into the high pressure fuel pump cause the #6 spark plug from firing? Maybe a little more info on my part this is on a 2002 EFI and there is absolutely no spark to #6. When the spark plug is pulled it has fuel on it but shows no sign of firing. Looks brand new but wet.
