To replace the gauges is it as simple as buying them on e-bay and plugging them in? The current ones work but the LED's are shot. What should I look for? Thanks.
replaces gauges for a '98 250 hp
no uppy, it is not as simple as that. yamaha has started using the same guages for all there motors, 2 and 4 stroke. new guages have tiny dip switches in the back to switch from 2 or 4 stroke, different pole settings for different motors and one other to change display units(mph/kph). they should come with a tag in the box to show you how to set them. hope this helps.Michael Babuchna
if you use a new guage, you need to get a new harness. on a new one you get both the oil and trim harness in one. on the older guages, they are seperate. the plugs are different but i cant remember exactly when they changed the plugs.Michael Babuchna
