I have twin 1989 200, one runs fine,while the other rpms vary 1000 excessive oil use and smokes. I would appreciate any help.
1989 twin 200 one excessive oil use
there are actually several things this could be. one could be busted fuel pump diaphram. another is the check valves in the oil injection lines. a quick check for this is to remove the carb cover and tilt the motor all the way up. wait a few minutes and see if you see oil coming out the carb throats. if you do, the replace the check valves. it is a cheap fix and you should do all 4 togerther.Michael Babuchna
