I know this is the Yamaha Web Site... But I've had good intelligent answers before. Please read over as I haven't gotten any help on the Mercury Web Site
I have three beeps when I turn on the key, and then the alarm goes off (proper testing at start-up). After I start the boat I get a pulsing alarm almost immediately indicating an Oil Alarm.
I have checked the oil to the engine mounted oil tank and it is full as well as the reservior tank. The cap of the engine mounted tank has a sensor which I have checked by checking for continuity (none) with the cap on and full continuity with the cap removed (simulating an empty tank). I tried to check the rotational sensor without sucess, but I tried a "used replacement" and had the same problem. I've hooked up a remote fuel tank with a 50:1 oil mixture and ran the motor with the oil line disconnected at 1500 RPM and got the proper 9cc of oil output and raised the oil arm (simulating wide oped throttle) and got 20cc of oil which is what the manual states is correct. I checked the voltage on the purple wire comimg from the terminal and it was showing full voltage. I went ahead at this point and and replaced the $240 oil warning module. Disgusted, I still have the same alarm! I do not see any wires that look to be shorted and I have a good ground throughout.
My best guess is it's still the oil pump rotational sensor (which several people have told me never go bad), the magnet on the oil pump shaft, or something simple like a horn malfuntion or the ignititon switch. The motor runs fine.
Please someone read this lenghthy posting and help!
Mark
Mark
