trim/tilt wont lock down
  • trim/tilt wont lock down
    I have a yamaha F100, the trim and tilt works fine, lifts up and down perfect but when I select reverse the engine jumps out of the water.
    Any ideas???
    Check the upper pin on cylinder to see if broken, if ok then there is a internal valve not holding pressure and the power trim would have to disassembled and rebuilt.
