Just wanted to let it be known that I got my '94 70hp running! Thanks to the sound advice I received on this forum, she is purring like a kitten now... Thanks all!
Guess I should have started from the last thread.... I was discussing the intense white smoke that was coming out when getting her started, and was only able to have the motor start for a few seconds with the help of some starter fluid. Well I drained the carbs of the 50:1 mix and put in regular gas and she started right up. I quickly re-attached the oil tank and the oil pump seems to be working fine, so I guess the problem was just too rich a mixture? or I don't have the carbs tuned perfectly... but either way, its good to have it functioning.
