LCD Marine Meter, 130HP Yamaha 1993
  • LCD Marine Meter, 130HP Yamaha 1993
    I have a 130HP engine with the trim indicator on an LCD Marine meter on the console. a couple of months ago the bars that indicate my trim quit moving.
    As soon as I turn the ignition on it darkens the first bar on the bottom and it does not move no matter where the engine tilt is positioned.
    I have checked all the wiring and cleaned and lubricated all the connections. The tilt works instantly from the engine or from the console, this tells me there is not a hydraulic problem
    Question? Is there a sending unit somewhere that tells this meter what to do?
    if so where is it?
    Pablo
    Check the trim sender that is mounted on transom bracket(just above trim motor). It has a spring loaded lever on it that should go back to up position when you move it down by hand, if stuck try to free up with oil.
