My engine is a 2000 225vmax ox66 and it has a low water pickup, and there is no way to put ear muffs on it, does anyone know of something that attatches to the cone to run the engine off of a garden hose? You can't run the engine off of the flushing attachment that the motor comes with can you?
running dry
blazer,
I think you can run the motor with just the flushing attachment - your owner's manual should explain this. Don't have an owner's manual? You can view them at this link:
http://www.yamaha-motor.com/outboard...home/home.aspx
Personally, I would not run the motor with just the flushing attachment. I don't see how that runs water thru the water pump. I think you would be better off coming up with a flushing TANK like I did. Check Wal-Mart. Get the biggest plastic bin they have. You will need to provide some side support for when it gets full of water. I just use some bungee cords from side-to-side and run them over the top of the upper casing just above the cavitation plate.
Ken K
ÂÂÂÂÂÂ
