I have recently purchased a 1985 Yamaha 40hp ERSX tiller handle version. Excellent condition, runs perfectly, however......it is a premix, not direct oil injection. Was this model a 2 stroke premix, or has the oil reservoir and oil pump been disconnected? I have looked online to compare to other 1985 Yamaha 40hp, and I see the oil tank is mounted on the port side, and see where the mounting screw holes are on my outboard. Would appreciate an answer from a Yamaha expert on this matter. Also, wish to upgrade tiller handle.....have read answers on part no. for tiller and fitting parts to upgrade to similar models, just not a 1985 series. Just want to know it applies to this model too. Thanks in advance for any reply.
1985 Yamaha 40hp ESRX questions.....
A 40ESRX was an oil injection model. Appears that someone disconnected the system and went to premix. A shame.
Provide the complete ID for your motor. Should be on a label attached to the left hand clamp bracket.
What tiller handle, by part number, do you want to use?
Originally posted by boscoe99 View PostA 40ESRX was an oil injection model. Appears that someone disconnected the system and went to premix. A shame.
Fitting Kit-6X4-42102-63-00
Also, if it is POSSIBLE to ask, I can upgrade to an electric start as well? Starter motor part number I have researched is 6H4-81800-12-00. Will need a new flywheel.....? Other parts needed......?
Originally posted by 99yam40 View Postthere is no 40 ESX listed for 1985 either
Originally posted by boscoe99 View PostHow about a 40ESK?
But a 40ESK came with an electric starter motor installed. That is what the E is for.
I don't see a 6X4 tiller handle working on that model.
Do you have the complete engine ID? Should be on a sticker on the left hand clamp bracket. Will begin with the number 6. Looks like this
https://www.google.com/search?q=yama...iBiHxBhXcqMlM:
Originally posted by Speckiller1957 View PostWell, Hoss, all I can go by is this... 1985 40ESK Yamaha Outboard Parts
as Boscoe said look at the tag and report back exactly what is written on the motor ID
Â
