Hi all,
I know this has been asked before.
Just removed my balancers on pair of 09 f150's.
Balancer spins freely and looks ok, but has a slight whine at idle.
Going to remove the internals and replace and see how it goes.
My question is on oil pressure once the internals are removed.
Id imagine with the shaft/bearing assembly removed there would be a risk of low oil pressure due to increased flow.
I noticed there is a grub screw on the block directly above the oil passage leading to the balancer oil port.
Instead of drilling and tapping a plug in the balancer, I'm wondering if I could simply screw the grub screw in the block down?
Cant find any reference of this screw in the manual.
