Part Numbers
  • Part Numbers
    I have a 2012 F150 (1000hrs) that appears to have crankshaft seal leak. Does anyone have the correct part numbers for the wear collar, not speedy sleeve, oil pump and crankshaft seals?
    www.yamahaoutboards.com.
    All parts and part numbers used on your specific model (what ever it may be) are in the parts catalog.
    You can simply type the engine PID into a search box and it will take you directly to your engine, by serial number.
