Hello engine yamaha F 100 2003 I will expose my problem trouble-free starting the engine rises to 1100 trs then goes down to 850 trs turns very well to slow after a warm-up period I leave that's where the problem comes in. I can not get over 2000 trs for about 3/4 hours to 1 hour it works well from this period takes all these tricks just a piece of information when the engine is not working well it's quibbling and it stops for no reason when I try to speed up carburetors open up to the max Thank you for your help greetings
yamaha f 100 problems
Originally posted by pstephens46Too much coffee?
But since I am struggling to speak/understand a smidgeon of Spanish I shall not criticize someone that can write in a non-native language. Which I think is the situation here. That or the OP is from Savannah.
We folks here in Kennesaw like Savannah. If it weren't for Savannah we would have no one to look down on.
Originally posted by boscoe99 View PostWhat we have here is an apparent failure to communicate.
Shamed into deleting my *****y commentLast edited by pstephens46; 12-05-2017, 08:07 AM.
Originally posted by michel92 View PostHello engine yamaha F 100 2003 I will expose my problem trouble-free starting the engine rises to 1100 trs then goes down to 850 trs turns very well to slow after a warm-up period I leave that's where the problem comes in. I can not get over 2000 trs for about 3/4 hours to 1 hour it works well from this period takes all these tricks just a piece of information when the engine is not working well it's quibbling and it stops for no reason when I try to speed up carburetors open up to the max Thank you for your help greetings
When it is not working right it takes full throttle to get to 2000 rpm..and is missfiring ( quibbling )
Maybe this is correct.
I have no clue.
For the Op.
Can you list, separately, (like this) exactly what's happening?
Normal operation and when acting up?
**Re-reading the post it seems AFTER warm up issues begin.
For 45 minutes to an hour, he cannot get over 2,000 RPMs, throttle doesn't respond to acceleration/RPM's.
Is that correct???
(Sounds like warm idle is a bit high, 850 too)
.Last edited by TownsendsFJR1300; 12-05-2017, 08:48 AM.Scott
Originally posted by boscoe99 View PostWhen was the last time the carburetors were thoroughly cleaned and synchronized?
By thoroughly I mean completely dismantled and cleaned in a heated ultrasonic cleaner.
What country are you in?
Originally posted by panasonic View PostMy interpretation. The engine starts and idles OK. Then it will not go over 2000 rpm for 3/4 to 1 hour. After this it works well? ?
If I was to guess,
If the engine shows symptoms after warmup look at ignition coil(s) faulty.
Or from last OP post, the engine is overheating, the most common culprit would be the water pump.
People on this forum will try to tease out more information in order to work out how to tackle this.
