I just bought an air compressor. Trying to separate the electric motor from the pump drive housing. Anyone have any good ideas as to how to remove the crank shaft from the electric motor shaft? Can't find anything for a puller to grab on to. Anyone think that the shaft might be pressed on, in which case will a slide hammer remove the shaft? Thinking that the slide hammer gets screwed onto the shaft, to pull it out, so that the crank shaft throw will come off the motor shaft?
Help.
Help.
