I have purchased a 50TLR 2006.
The engine has very poor performance at wot (about 10hp speed)). It also has a rough idling with sounds like backfires (I'm not a mechanic by the way)
I've been through 2 different repair shops. The first shop checked everything it could but didn't find the problem. The second one is a yamaha certified dealership with certified technicians. There diagnosis: a crooked crankshaft of 30mil where the flywheel sets in. It's almost not perceivable with the naked eye. They say that's enough to cause bad timing on the engine.
Both shops checked compression, spark plugs, coil, carburator, etc. Everything checks ok.
I have filmed a test that I made of the engine at wot :
https://youtu.be/73fDWV-tBfk
It runs rough and won't rev up at wot.
Can it be a malfunction that enables the rev limiter to kick in?
Do you agree with the diagnosis of a crooked crankshalf?
Thanks in advance
Regards.
JF Leblond
Thanks in advance
Regards.
JF Leblond
