My middle carb is spitting fuel out the front of the carb past the choke butterflies. I dissambled the carb and everything looked fine. I then removed the intake manifold and looked at the reeds - all good none broken/none appear to be sticking. Any ideas besides reeds what might cause this? Air leak at the manifold gasket maybe? Compression tests on the two middle jugs was OK.
86 PRO V150 carb problem
