gearcase drain plug leak
I would have though a couple of PSI would be adequate to simulate actual pressures encountered in operation.
10 PSI, although clearly specified in the drawing, might be a tad too high in that it might actually make the seals seal better by pushing them harder against the shafts, thereby masking the possibility that they maybe actually not be quite tight enough fitting (worn out or hard), allowing some water to pass through under normal operating pressures.
Originally posted by zenoahphobic View PostI would have though a couple of PSI would be adequate to simulate actual pressures encountered in operation.
The PSI is just to make sure the unit is sealed tight and water will NOT intrude (or oil leak out). 10 PSI for such a short period is plenty to make sure the LU is water tight (which is the bottom line).
.Scott
Originally posted by pstephens46 View PostSuch an easy, quick test as shown by Scott's post. Amazing the pages of posts over at THT on leaking lowers. Just a simple test, that's all.Scott
Originally posted by TownsendsFJR1300 View PostThe LU oil DOES have to be removed for testing purposes...
I am not ragging on the OP. Just amazing that some on other sites make things so hard. Such as advice like this. "To find a leak, wait until nighttime. Get a flashlight with a purple lens. Lay down on back under lower unit with light and wait for a dribble. Could take awhile"
Or my favorite. "Go out and sniff your lower unit. Lower unit oil is stinky"Last edited by pstephens46; 12-15-2017, 08:03 PM.
ÂÂÂÂÂÂ
