I have a motor that was manfactured in july 2004 but is titled 2005. The info from the frame plate calls it a F75TLRD. I ordered a aftermarket trim motor, part #6D8-43880-01-00 which won't make up do to different shaft length. It is supplied with a connector, but the bottom which goes to pump drive is wrong gender. That motor is returned.
After a lot of research I found part numbers for a trim motor for 2004 and earlier, F75TLRC. I can't establish the proper length for the aftermarket from the vendor. The length of my old motor's shaft is 1-1/2" I need help without just ordering another motor. Has anybody run into this mess before? ?My engines serial is #1003674
