First year of ownership on this particular outboard and am getting ready to winterize.
Owners manual is quite vague to say the least
Anyone know the procedure for treating fuel system as far as running treatment through the engine.
I am familiar with other outboard winterizing standard procedures such as stabilizing fuel in tank, lower unit gear lube draining, fogging cylinders through spark plug holes, changing fuel filter/water separator greasing fittings and spline on prop shaft.
Also I have read that the F350 has a limited history at minimum of holding water and freezing does the 300 need any special procedures to prevent water being trapped and freezing.
Interested in hearing what others are doing in climates that require winter layup - other than moving further south
Want to make sure I cover all the essentials.
Thanks in advance.
Thanks in advance.
