Ok guys I know this isn't really a Yamaha product but im sure a few of you know what to look for. I bought a used Seastar Hydraulic steering kit for my 225. I went to install it last night and started the bleeding process. I first hooked up the lines wrong then found out they need to be opposite. I can get the motor to turn all the way to the left and bottom out no problem with clear fluid coming out of the bleed screw. Closed that off then go to turn back to the right and it wont do anything the wheel just keeps spinning and spinning. I ran almost 4 quarts of fluid through it thinking I Just needed to keep bleading it but nothing. Any help would be awesome.
Seastar Hydraulic Steering problem
are you sure you are bleeding correctly? and make sure you keep the helm supplied with fluid so it doesn't run empty
pages 2-5 :
http://www.seastarsolutions.com/wp-c...5/200017-B.pdf
I bled both sides till I had a nice steady flow with no bubbles coming out, but the motor still would not turn to the right. I can get it to turn to the right with the steering wheel if I open both bleeder screws. Once you close the bleeders screws the motor will turn back to the left all the way but then wont back back to the right again.
Ok update on the situation, I can get the motor to turn the other way now, but the bleeder has to be open and the steering wheel still keeps free spinning, if you close it the motor stops turning. I bled the system all the way and no more air would come out of either side. I’m thinking that spool valve is stuck to one side.
The helm unit will bleed air as well, set up an inverted bottle of fluid above it, like an IV. Turning the wheel back and forth with the piston bleeders closed will expel air in the helm unit. Skip the seastar fluid, power steering fluid from an auto parts store works just fine.
Originally posted by scofflaw View PostThe helm unit will bleed air as well, set up an inverted bottle of fluid above it, like an IV. Turning the wheel back and forth with the piston bleeders closed will expel air in the helm unit. Skip the seastar fluid, power steering fluid from an auto parts store works just fine.
Originally posted by Phillips_211 View PostI can get the motor to turn the other way now, but the bleeder has to be open
The ram is absolutely simple, just a single piston in the center. No valves (except the bleeders) - no other moving parts.
When you turn the helm wheel , it pumps fluid into one side - BUT -
for every molecule of fluid pumped into one side,
a molecule has to exit the other side -
it has to return to the helm.
If the ram only moves when you open a bleeder, then you are successfully pumping fluid in -
that means there is a fault in the helm preventing fluid from returning from the other side of the piston.
Update: I was working on the boat last night and looked over at the steering wheel and thought to myself maybe if I **** the steering wheel hard to the side it wont turn it might start working. Sure enough I grabbed the steering wheel and bumped it really hard to the side it wouldn't turn and you could hear something break loose. Im assuming it was the spool valve that was stuck to one side. I still think it needs attention because I can hear the valve moving left and right when I turn the wheel.
ÂÂÂ
