Blue Sea Systems, BEO, Cllena, Perko, Attwood, Joey Chitwood, Field-Disconnect etc etc. etc.
OK, After taking V readings from all over the map, and my general level of disgust with the rigging of my 12 year old yacht-t-t-t-t-t (Raymond Luxury Yacht-t-t-t-t) I have decided to remove, and smash into tiny bits my old Perko 8501 switches. When I select OFF, I expect to see zero volts at the engine, not 2.5 or some other random number.
1. Do I need a switch with built in Field Disconnect?
2. What switch do you recommend?
3. Or, which do you NOT recommend?
Here's the set-up.
Two 2005 YAM F225 4 Strokes
Two 850 CA deep cycles.
One 100 Watt Solar Panel who's primary function is trickle charging when the boat is not in use.
The advantage of sticking with the Perko 8501 is that they're vertically stacked, one above the other which greatly facilitates the wiring set up. There are 8 inch pig tails running up from switch one, to switch two. I'd rather not have to rewire the whole mess.
A bit surprised at the number of available switches, so I could use some enlightenment. Light me up, if you will.
Here's the set-up.
