Hi All,
Been doing a lot of reading through past posts and I'm wondering about a few things that I've caught bits and pieces throughout.
Engine S/N is 6FNL-1007150
Yamaha 703 side control
Stock analog speed/tach/volts/fuel at the console. No lights for oil pressure or temperature.
I would like to install an NMEA2k backbone and LMF-200 indicator as well as feed the NMEA2k data to my Helix 10 gen2. In addition I wanted a dedicated analog trim indicator.
1) Can I install the analog trim indicator using the trim/oil harness?
1a) If yes, what color are my wires supposed to be on the engine connector for which the trim/oil harness connects? I believe I've located the correct plug, it is greenish plastic with 4 wires; 2 pink with black stripe, 1 green with a white stripe, and 1 solid pink.
2) Does my motor provide an NMEA2k output?
2a) If yes, what color are the wires for the NMEA connector at the motor? I believe I've spotted the candidate which has 2 wires, 1 blue and 1 pink going into a white 4 pin square connector.
3) If I'm using the analog trim indicator, will the trim data still be available on the NMEA2k bus?
Thanks,
Thanks,
