I had to replace my trim switch which I did with no problems. When I went to put it back together I dropped it and had parts flying. I got it back together put had 2 parts left over see attached. I can get it back together but it shifts hard please help.
703 throttle control
Looks to me like it goes into a nesting spot on the inner surface of the outer cover. Item number 25. Right below where the kill switch is installed.
Item 22 is called a cable anchor so it seems to me that it would be part of the stuff that attaches one end of the control cables to the control box. Seems to interface with item 58 which is a grommet.
Different illustration below showing the cable anchor from a different perspective.
Originally posted by Norforkguide View PostThat's look like its where it belongs. Can you point me to a parts list description where I can order some parts.Dennis
You may have to wait for Boscoe to come back on that one or one of the other more knowledgeable guys out here to help then.
Best I can help is you can go to the above and in the search box at the top of the first page type in 703 Throttle parts and you may find on the list the year of your throttle and a diagram of the parts and numbers.Last edited by dray0151; 09-09-2017, 07:32 PM.Dennis
703 control
This was suppose to be simple task and it has snowed ball down a slope where now I have a broken part I cannot find on the schematic and no control box. We have a another control box that is new off a 115 yamaha 2015 are the boxes interchangeable mine is a 2009 my motor is a 2017
703 control boxes are interchangeable.
The part behind item 15 is item 19 in the first illustration.
It is item 17 in the illustration linked below:
2006 and Later Rigging Yamaha Outboard CONTROL STANDARD SIDE 703 PUSH Diagram and Parts
Is it item 24?
You can go to the Yamaha US website and look at exploded views of 703 control boxes. Look until you find the part that you need. Plug the part number in the boats.net search box and it will give you price and availability.
Have you thought of taking the control box to a Yamaha dealer to have him fix it for you?
ÂÂÂÂÂ
