I have just installed this engine and need a bit of help. The fuel line is about 10 ft long and the tank is about 4ft below the engine. Priming is a bit difficult with the bulb and needs to be pumped on each starting. I would like to install a 12v in line pump to make things easier.. A wiring diagram would be helpful to identify the color of the wire that goes live when the key is turned so I can wire in a pump.. I have had difficulty in finding a diagram. any advice is gratefully taken. Chris.
F9 9AE 9.9hp Four Stroke 1995.
