Originally posted by rodbolt17
View Post
An Intro and Some Questions (VST, LP Pumps)
Originally posted by JerEazy1 View Post
VST needs some extra reviews.
F150 VST filter replacement - The Hull Truth - Boating and Fishing Forum
.Scott
Originally posted by rodbolt17 View Postnot really any similarity to the F150.
the OX motors are way easier.Scott
thanks - ordered new VST gasket and filter, 2 new LP pumps and gaskets as well (2 new control cables too as a precaution - but that's in another post).
Will tackle that fun next week when the parts arrive- Eazy Life
The screws that hold the top of the VST on are puny and soft. Use care when removing them. I ended up putting them back in with anti-seize and spraying the top of the VST with a light coat of Fluid Film as I never want to have an issue with them.
The "filter" on the bottom of the high PSI pump is nothing more than a small screen in a plastic gizmo which slides onto a fitting on the HI-PSI pump. No need to replace it, just give it a shot of Carb cleaner if the screen is still viable.
The High and Low PSI pumps are crazy expensive. Shop carefully when the time comes to replace them.
The vst screws are a little scary. I went the impact driver route and was surprised on two counts. I had to hit the driver solidly three times to get the screws loose. No damage to screws at all.
ÂÂÂÂÂÂÂÂ
