Engine/Prop RPM Question
  • Engine/Prop RPM Question
    My 1999 C90 Yamaha will crank 5500 RPM's at WOT with ease....the book says the gear ratio is 13:26 (2.0)....so how many RPM's is my prop turning at an engine speed of 5500?.....
    the convention is that the ratio is stated as engine/prop
    so 2:1 - the engine turns twice for every propeller revolution
    5500 engine rpms the prop is turning 2750
    which begs another question:
    do driveshaft seals typically wear out sooner than propshaft seals?
    and if so - is the reason the difference in shaft rpm?
      Deleted
      - Eazy Life
        Robert you know better, cranking and WOT do not relate to each other
        and a lot of prop seals go bad due to fishing line not just wearing out
        Robert listed ratio a 1 to 2 and fairdeal listed ratio 2 to 1
        seems a little different
