how to test low pressure lift pump
  • how to test low pressure lift pump
    1999 DX50TLRX
    It has 2 pumps How exactly can these be tested
    Thanks Mike
    Don't see that model number in the list on this site....
      probably missed a 1
      150 not a 50
        yes a 150 HP DX150TLRX
        LP fuel pump Part #6E5-24410-10-00
        Test procedure is appreciated
          Will the motor start and idle at all? It it will, you could dump the gas out of the clear filter bowl on the engine. Those pumps should fill it back up pretty quickly after starting.
          There is a pressure/vacuum test. Maybe Boscoe has the specs. I do not.....
            I think the test and spec are the same for mechanical diaphragm pumps, whether 2 stroke or 4 -
            applying pressure to the suction side - with finger over outlet pipe- should hold 7 psi without leakage
            applying pressure to the discharge side - suction side open - same
            applying suction, to the suction side - outlet side open - should hold -4 psi without leaking
              Thanks for your info
              I changed out both this morning and solved everything
                I believe these pumps can be rebuilt. Don't toss the old ones in the trash yet....
