Engine revision / weard damage
  • Engine revision / weard damage
    I'm rebuilding a 2-stroke 200 hp from 1999. Before assembly i inspected the cylinders for any damage. 5 out of six seems to have piston marks in the bottom of the block. See picture. Is this normal? If not any idea how this could happen?
    I do not understand what is in the pic
      Nor do I...please take a few more pictures further back so we can get our bearings on what you are trying to show...
        Just studied picture for 5 minutes, no idea what it is either.
          If you look into the ( empty) cylinder, and look into the connection rod "pass trough" to the crankshaft. The damege seems to be created bij the piston pin bridge from the pistin
            Sorry, not seeing it.
            have you opened the pic you posted?
            too close up to tell what we are looking at
            try a different pic
