Does anyone know if Yamaha is paying for the repairs when the balancer goes out on these model motors? Pretty sure that is what has happened to mine after reading all the reports on here.
2005 F150 balancer
F150
That is what is figured..... I'm gonna take it off and see how bad it is. Hopefully there is no internal damage.
What did you notice? Was is whining and then stopped suddenly while motor running? Oil pressure alarm?
Yamaha won't replace it, too old (and out of warranty)
Just asked Mamma Yamaha last week.
You want the latest unit, type FOUR.
.Scott
When was the start of type four
Not that either of mine are having balancer problems. (knock on wood)
Just was curious when type four started being used. I have one 2008 & one 2010 (F150)
Originally posted by Kirk Gibson View PostNot that either of mine are having balancer problems. (knock on wood)
Only up to 2011
Unless I'm reading it wrong it appears like the list only goes as high as 2011, and as of that year they show type 3.
Kirk, my '06 engine was changed out to a type 3 under warranty.
I, after the warranty expired, (and they put out type 4) was told by Yamaha the type 3 is fine. Some very slight differences to quiet it down. NOT like the type 2, that failed.
You may call Yamaha tech to confirm the above:
http://www.yamaha-motor.com/corporate/contactus.aspx
http://www.boats.net/parts/detail/ya...500-04-00.html
http://www.simyamaha.com/BALANCER_AS...0-04-00kit.htm
.Last edited by TownsendsFJR1300; 07-25-2017, 07:48 AM.Scott
Originally posted by Kirk Gibson View PostUnless I'm reading it wrong it appears like the list only goes as high as 2011, and as of that year they show type 3.
Then the F150A was introduced.
Then the F150B was introduced.
Then the F150c was introduced.
The -04-00 balancer was introduced in 2012. Mid-stream during production.
Looks like some training in the use of the parts catalog is needed.
Originally posted by TownsendsFJR1300 View PostKirk, my '06 engine was changed out to a type 3 under warranty.
The -03-00 is so fine that they decided to update it just because they could. Engineering was slow so they updated it just to fill their time.
Your motors do not have the latest part number balancer.
Yes thats what I thought. Does the type 3 have steel gears?
The last two times I changed the oil in the engine, just for kicks I strained the oil through a nylon stocking to see if there were any particles of anything. I know the oil filter would probably catch anything but I wanted to see if there was even a tiny particle....nothing...clear. I think I won't let this balancer thing worry me until I can actually hear something. Life is too short.
ÂÂÂÂÂÂÂÂ
