oil pressure sensor
  • oil pressure sensor
    Hi, how do I change a oil pressure sensor on a 2004 Yamaha f225?
    unplug the wire connector, then back out the threaded sensor
    don't try using the plastic housing - there's a hexagonal steel base
    takes a 17mm or 11/16 open end
    but unless you bend or make a wrench,
    you will need to remove the air intake (and battery cables) to be able to reach it
    [/url]
