Fairdeal - question on Fram oil filter
  • Fairdeal - question on Fram oil filter
    Fairdeal:
    How did you determine the Fram filter was a match for your F225?
    need to find out if the filter needs to have a check valve in it to keep the filter from draining when motor is turned off,
    some do, from what I have heard
      just painstaking Googling of the details of each manufacturer's spec
      IMO the "critical" parameters are dimensions -
      obviously the canister has to fit, the thread size and gasket has to match
      anti-drain back valve and bypass valve are pretty standard
      although - IMO - not critical anyway - in my engine
      nor do I give much thought to the "filter media";
      I "baby" the engine, but change the oil (and filter) anyway every 100 hours -
      so I don't figure the oil filter has much work to do
      and I'm old enough to remember when there were many autos on the road
      that did not even have an oil filter....
